ATP500 Arp Spoofing detection
    PeterUK Posts: 4,136 image  Guru Member
    No more IP conflicts messages now
  • Pook
    Pook Posts: 151 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    Having this issue on a ATP 800 too, any updates?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,350 image  Guru Member
    Hi @Pook
    Please refer to our V5.35 WK06 firmware, we already fixed it. Thanks.
  • Pook
    Hi @Pook
    Thanks Jeff, appliance is on Nebula V5.35(ABIQ.0) (Latest), do I just deploy via local web GUI?
  • Zyxel_Jeff
    Hi @Pook
    We can update the firmware for you when you are available. I will send a private message to you to arrange the schedule :) .
  • c777
    c777 Posts: 14 image  Freshman Member
    Hello, I have the same issue ip address conflict is detected. 00:00:00:00:00 on 5.35 abar0 usg20W-vpn
  • MBS
    MBS Posts: 3 image  Freshman Member
    ATP 100 V5.35 (ABPS.0) Tengo el mismo problema de conflicto de IP con numerosas IP en diferentes VLAN con mac 00.00… pensaba spoofing no gano para sustos
  • Zyxel_Jeff
    Hello @c777 and @MBS
    Please use the V5.35 WK06 firmware, the firmware already fixed this problem. Thank you.
  • Mk88_it
    Mk88_it Posts: 73 image  Ally Member
    Hi jeff, we have the same issue on an ATP200 on nebula with firmware V5.35(ABFW.0) (Latest)
    How can we do?
  • Zyxel_Jeff
    edited March 2023
    Hello @Mk88_it
    Please enable "Invite Zyxel support as administrator" on the Nebula and provide your org and site name to us via private message. We can arrange a scheduled firmware update when you are available. I will send a private message to you later. Thanks.
