False malicious activities / windows update
Hi @Zyxel_Kevin,unfortunately, the issue is still prevalent on our USG 500 flex. False positives still happen every month on MS patch day! It often involves some kind of dotnet-runtime-file, today it was the Update KB5023288. The Hash is 28F846B09CB2CFE30ADDFC2731853AF9.You really should look at this - adding files to the allow list every month by hand or posting here is not a sustainable solution.Thank you very much.1
Here is the same procedure every month on Windows Patchday with a USG Flex 200. It is getting tedious to feed the white list every month.
HI @Vagabound,
Sorry for inconvenience caused. It is in our roadmap, and the solution would be ready at the end of April.0 -
Vagabound said:Here is the same procedure every month on Windows Patchday with a USG Flex 200. It is getting tedious to feed the white list every month.
At least you have a whitelist
On Nebula you don't even have one. So we are stuck with installing by hand or disable the sandboxing feature.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
