iPhone error "Cannot verify server identity 'outlook.office365.com'" behind ATP100
ChipConnJohn
in Security
Hello All,
I started getting a pop-up on my iPhone today.
Cannot Verify Server Identity
The identity of "outlook.office365.com" cannot be verified.
When I click Details on the error I see:
dnsft.cloud.zyxel.com
issued by Amazon RSA 2048 M01
I can't find any app that isn't actually updating. I think it's the iOS Mail App that's causing the pop-up as when I'm behind the ATP100 I see an Account Error at the bottom. This goes away if I use cellular. Either way the email is getting updated, however.
Any ideas why the ATP100 is getting in the way of verifying this certificate?
Thanks,
-John
Thanks,
-John
Hi @ChipConnJohn,
Greeting Forum, there is flase positive by content filter.
The site has been categorized into the correct category.
If the issue still we can have remote session to check issue. Thank you
Kevin0 -
Hi all,
same here: MS Outlook 365 23.01 behind ATP100W....Since a few days, and everytime we start Outlook, there are one or more of this security alerts, with different MS-domains....Thanks! Chris
Same here as Chris71 (behind ATP500) with the following signatures:
Hmm, probably this helps... we'll give it a try:
Perfect! Seems resolved and article makes sense.0
Hi @Freddy,
Greeting Forum.
Actually the accidient had resolvd on 2/14 10am GMT+1.
Please try to clear your DNS cache and check if the issue still persist.
Thank you
Kevin
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 495 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 456 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
