False malicious activities / windows update
12346»
  • st3213
    st3213 Posts: 9 image  Freshman Member
    edited February 2023
    unfortunately, the issue is still prevalent on our USG 500 flex. False positives still happen every month on MS patch day! It often involves some kind of dotnet-runtime-file, today it was the Update KB5023288. The Hash is 28F846B09CB2CFE30ADDFC2731853AF9.
    You really should look at this - adding files to the allow list every month by hand or posting here is not a sustainable solution.
    Thank you very much.
  • Vagabound
    Vagabound Posts: 49 image  Freshman Member
    First Answer First Comment Friend Collector Third Anniversary
    Here is the same procedure every month on Windows Patchday with a USG Flex 200. It is getting tedious to feed the white list every month.
  • Zyxel_Cooldia
    HI @Vagabound,
    Sorry for inconvenience caused. It is in our roadmap, and the solution would be ready at  the end of April.
  • Dexta
    Dexta Posts: 16 image  Freshman Member
    At least you have a whitelist ;) On Nebula you don't even have one. So we are stuck with installing by hand or disable the sandboxing feature.
