SecuExtender Agent: VPN drops when user attempts to login with RDP
PeterUK said:By default its 1370 so someone changed it...
Kudos to you btw. Your input didn't go unnoticed. I did see that you mentioned the MTU size first. I believe I said something to my co-worker about that yesterday. That is probably what lead him to finding the article by Zyxel_Kevin. Thanks!1 -
I have a new HP laptop pavillion 15. The MTU is set for 1370 as soon as the RDP connects the ssl disconnects. I have tried everything in this thread, updated to the latest, install windows Pro, tried different wireless cards. rand DISM and SFC, I have 2 identical machines doing the same thing.
They have Intel® Wi-Fi 6 AX201, I did try an external WI-FI card with the same results. Could it be that without a built in Lan card that this is happening?
Are you sure you are setting the MTU for the "TAP-Windows Adapter V9 for Zyxel SecuExtender"?
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 486 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 454 News and Release
- 4.3K FAQ
- 93 Security Highlight
