GS1910-24 VLAN
Onur
Onur Posts: 6 image  Freshman Member
edited February 2023 in Switch
I have completed the configuration as vlan3 and vlan4 on sophos firewall. Although I pull to vlan3 or vlan4 on gs1910-24, devices connected to port1-2 cannot get IP.
What else do I need to do? thanks
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    Hi @Onur,
    The port VLAN configuration of Sophos firewall connecting port is recommended as below:
    1. Port VLAN should be "1" if your management VLAN is 1.
    2.  Egress tagging should be "Untag port VLAN".
    3. Allowed VLAN should be "1,4"
    Also, the port VLAN configuration of end devices connecting ports are recommended as below:
    1. Port VLAN should be "4".
    3. Allowed VLAN should be "4"
    Hope it helps.
    Zyxel Melen
  • Onur
    The cable from the firewall is plugged into port 24. The computer with Windows is plugged into port 2. Management port is in vlan1.but windows computer is not getting IP
  • Onur
    problem is solved. The problem was caused by the dhcp distribution being turned on.
