Ssl vpn does not work whit usg40
Hi, I have this problem with a usg40 (I have other configurations working correctly on other types of models, for example atp 100 , usg 60 , usg 110 and usg 210).
When I try to connect in ssl vpn on this usg 40 last updated firmware, the ssl vpn from me does not start and gives me the following error (il log del secuextender):
[ 2023/02/22 15:47:58 ][SecuExtender Helper] Request(104): REMOVE 515025088/2728275805 15 4294967295 4294967295
[ 2023/02/22 15:47:58 ][SecuExtender Helper] Remove Routing
[ 2023/02/22 15:47:58 ][SecuExtender Helper] Remove prioritize routing
[ 2023/02/22 15:47:58 ][SecuExtender Helper] Get netsh path = powershell
[ 2023/02/22 15:47:58 ][SecuExtender Helper] Set-NetIPInterface -InterfaceAlias "Ethernet 2" -InterfaceMetric 30
[ 2023/02/22 15:47:58 ][SecuExtender Helper] ZyShellExecute start.
[ 2023/02/22 15:48:02 ][SecuExtender Helper] ZyShellExecute WaitForSingleObject() result = 0
[ 2023/02/22 15:48:02 ][SecuExtender Helper] GetExitCodeProcess
[ 2023/02/22 15:48:02 ][SecuExtender Helper] lpszFile = powershell, lpszParam = Set-NetIPInterface -InterfaceAlias "Ethernet 2" -InterfaceMetric 30, dwExitCode = 1, dwError = 0
[ 2023/02/22 15:48:02 ][SecuExtender Helper] Failed to read from client(2): 109, 0
[ 2023/02/22 15:48:02 ][SecuExtender Helper] Start to Disconnect pipe...
[ 2023/02/22 15:48:02 ][SecuExtender Helper] Shutting down a pipe connection instance...
[ 2023/02/22 15:48:02 ][SecuExtender Helper] ==============================
Hello @Promos
The problem is fixed by enabling the option Enable Network Extension (Full Tunnel Mode)
James
Hello @Promos
Welcome to Zyxel Communtiy!
Is there anything in the USG40 logs? it could be a clue, and may I know your SecuExtender version? is it the same PC you connected to previously?
James
hi james, thanks for the reply.
I think the problem is not on the client side because I use my pc for other connections with other Zyxel firewalls and everything works very well. I think the problem is on the firewall side because I can't connect from another client either. Anyway my client version is SSL_VPN_Client_4.0.4.0.
Post the logs on the firewall side at the time of connection. For now I've done a workaround with an l2tp connection
Is it a local user or an external user?
It is a local user
Hello @Promos, I've contacted you in PM for further checking, please check your inbox, thank you.
Hello @Promos
James
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
