LTE4506-M606 - Webinterface - unable to enter "username"
mjr
mjr Posts: 39 image  Freshman Member
First Comment Friend Collector Seventh Anniversary
edited May 2024 in Wireless
Hello!
When trying to log in to the webinterface of my LTE4506-M606 it is not possible to enter a username, the field is blank and not accessible. It is not possible to loging, because of a missing username.
How can I enter a username in the field "username".
BR Jochen
  • mjr
    HI Zyxel_Joslyn
    Thank you for this hint. After a reboot and opening a new private window, the username was pre-filled.
    Maybe this could be corrected with a future firmware update.
    BR Jochen
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @mjr
    It’s suggested to use the New Private Window (Firefox) or the New Incognito Window (Chrome) accessing the LTE4506 page.
    If you use a regular window of any browser, it’s suggested to clear browsing cache in order to avoid this.
    You may also try to reboot the unit in order to recover from this, and you would see that the username is pre-filled in by the LTE4506.
    If you have further question of LTE4506, you may create a new topic at the below forum link.
    https://homeforum.zyxel.com
    Thanks.
    Joslyn
  • mjr
    HI Zyxel_Joslyn
    BR Jochen
  • Zyxel_Joslyn
    Hi @mjr
    We separate ZYXEL products into different forum pages. This forum is for Enterprise products.
    About your request, you could create another topic via the below forum link.
    Thanks.
    Joslyn
  • mjr
    Sometimes it would be easier to differentiate the correct assignment if there would be an extension in the product name (like "home use" or "business use").
