LTE4506-M606 - Webinterface - unable to enter "username"
Hello!
When trying to log in to the webinterface of my LTE4506-M606 it is not possible to enter a username, the field is blank and not accessible. It is not possible to loging, because of a missing username.
How can I enter a username in the field "username".
BR Jochen
BR Jochen
HI Zyxel_Joslyn
Thank you for this hint. After a reboot and opening a new private window, the username was pre-filled.
Maybe this could be corrected with a future firmware update.
BR Jochen0
Hi @mjr
It’s suggested to use the New Private Window (Firefox) or the New Incognito Window (Chrome) accessing the LTE4506 page.
If you use a regular window of any browser, it’s suggested to clear browsing cache in order to avoid this.
You may also try to reboot the unit in order to recover from this, and you would see that the username is pre-filled in by the LTE4506.
If you have further question of LTE4506, you may create a new topic at the below forum link.
Thanks.
Joslyn
HI Zyxel_Joslyn
BR Jochen0 -
Hi @mjr
We separate ZYXEL products into different forum pages. This forum is for Enterprise products.
About your request, you could create another topic via the below forum link.
https://homeforum.zyxel.com
Thanks.
Joslyn0 -
Sometimes it would be easier to differentiate the correct assignment if there would be an extension in the product name (like "home use" or "business use").0
- 435 Beta Program
- 176 Nebula Ideas
- 424 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
