Duplicate App Patrol Profile.
Is there a way to duplicate an application patrol profile on Usg Flex 500 device ?
Just to have a second profile, similar but with some little differences to be applied to another network, without the need to recreate the profile from the scratch
Thanks in advance to anyone who helps…
As far as I know, unfortunately, it is not possible to copy from the web interface. But I have previously copied and created a second app-patrol in the startup-config file in 2-3 companies.
No, that's one of the things you can only do via .config file editing.
Or maybe via (web)CLI/SSH.
I set the Syslog intervals via Maintenence → startup-config.conf → Download
Then edit the file, rename it to something, upload and activate. The device will reboot instantly!
When all goes well, the new startup-config.conf will be the one you uploaded (depends on upload-handling - set when uploading).
You can also do it via FTP. Same procedure – the device reboots on upload.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
