Duplicate App Patrol Profile.
Antonio_DEA
Antonio_DEA Posts: 1 image  Freshman Member
Is there a way to duplicate an application patrol profile on Usg Flex 500 device ?
Just to have a second profile, similar but with some little differences to be applied to another network, without the need to recreate the profile from the scratch
Thanks in advance to anyone who helps…
  • bymusty
    bymusty Posts: 25 image  Freshman Member
    Network Detective-New Adventure Badge First Answer First Comment Friend Collector
    As far as I know, unfortunately, it is not possible to copy from the web interface. But I have previously copied and created a second app-patrol in the startup-config file in 2-3 companies.
  • bymusty
  • StefanZ
    StefanZ Posts: 202 image  Master Member
    First Comment First Answer Friend Collector Second Anniversary
    edited February 2023
    No, that's one of the things you can only do via .config file editing.
    Or maybe via (web)CLI/SSH.
    I set the Syslog intervals via Maintenence → startup-config.conf → Download
    Then edit the file, rename it to something, upload and activate. The device will reboot instantly!
    When all goes well, the new startup-config.conf will be the one you uploaded (depends on upload-handling - set when uploading).
    You can also do it via FTP. Same procedure – the device reboots on upload.
