Problem with update ZyWall USG-100Plus to firmware 330 AACV v3.30P9 (WK48)
Well, glad I could help -)
H!
Hi @a1601 do you ave any previous version?
This is my actual:
BootModule Version: V1.17 | 12/01/2011 05:20:17
DRAM: Size = 256 MbytesKernel Version: V2.4.27 | 2014-09-22 13:31:25
ZLD Version: V3.30(AACV.6) | 2014-09-29 07:40:36using your file I got this error:
Booting...
Now booting kernel in FLASH
BM cmd line: console=ttyS0,115200 root=/dev/ram init=zyinit "-f -l 192.168.1.1 -r /dev/sda", address: 0x100000intird start:0000000084136000 size:00000000000781A3
vmlinux start:0000000084006000 size:000000000012FD5C
Uncompressing Linux...done.
mount: fs type sysfs not supported by kernelConnect a computer to port 6 and FTP to 192.168.1.1 to upload the new file.
Firmware received ...
Start to check file system...
DoneBuilding ...
[Update Filesystem]
Updating Code
/rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)
(may instead be incorrect password)Thanks for your help
Claudio
Hi Claudio. Sorry, I don't have previous versions.
Claudio, this is found from Internet (USG100-PLUS_3.30(AACV.6)C0.zip):
GREAT @a1601 with your files I have saved my Zyxel. Thank you very much!
Another question, is there a way to connect to the web console using a new browser and not an old one? With new one I got: ERR_SSL_VERSION_OR_CIPHER_MISMATCH and I have to connect with an old firefox version
Try this:
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
