USG60W WiFi set up
Dovetail_MD
Dovetail_MD Posts: 81  Ally Member
edited April 2021 in Security
I'm now puzzling over the Wi-Fi setup.
At the moment all I've done is accepted the default with a Main SSID and a guest SSID and changed the passwords to something more complex
It looks to me like neither of these SSIDs has LAN access as default?
Our previous setup was to have two "always on" SSIDs - a guest with no LAN access and another SSID for those devices that are allowed access to the LAN.
The other issue is that there is an oddness in which devices are allowed to connect which not - my modern SamsungGalaxy Note mobile phone will connect to the main SSID but my administrators older Apple iPhone will not.  Why?
So how do I set up to always on SSID similar to the original that we had as described above?
  • Dovetail_MD
    Sorry  - should have said - we have DHCP supplied by Windows 2012 server is also a DC of course and we do not use our subnet for the guest Wi-Fi as we cannot work out how to fix this
  • Dovetail_MD
    No one?
    I've changed the Guest to always on and now the bloody thing is not serving any WiFi at all.
  • Harska
    Harska Posts: 11  Freshman Member
    Try to reset to factory defaults, then make the initial setup with basic settings.
    Then create the home and guest WiFis, and do not use the DC as DHCP server.
    These 2 WiFis should work fine; but only home can access LAN
    If this is successfull then there are propably problems
    with the DHCP settings of the DC, and the IP parameters do not match
    with the IP settings of the router
  • Dovetail_MD
    Thank you - I have just discovered that the DC running DHCP does not have Internet access for some reason.  Work in progress!
    In the meantime I have put our previous gateway device back on the system as that has been reliable for two years.
    But are you suggesting turning on DHCP on the USG60W?
    Oh no I forgot - this is what screwed up our domain controllers originally as it came on as a default, picked up the DHCP addresses on the iSCSI side of one of the DC's and  the domain failed because it could not authenticate - it's given us a month of difficulties as a result.
  • Dovetail_MD
    Okay - DC that runs DHCP now has Internet access as well as network access.
    Put the Zyxel back on the network and it is not dealing DHCP addresses from the DC
    Is there any way of nominating the IP address of the DC that runs DHCP in this Zyxel so forcing it to use it?
  • Harska
    ZyXEL either is dealing the IP adresses (=has DHCP server on);
    or the DHCP is OFF (not dealing the IP adresses), and DC is acting as DHCP server.
    There is no way to make ZyXEL to distribute the DHCP addresses of DC.
    That is a communication protocol between the client and DHCP server.
    In that scenario; the ZyXEL is only routing the IP traffic
    (if setup correctly, ie. no FW rule blocking etc)
  • Dovetail_MD
    "There is no way to make ZyXEL to distribute the DHCP addresses of DC" - really?
  • Dovetail_MD
    Harska  - you are clearly talking rubbish - not the least since I have a mobile phone beside me now connected to the main USG60W Wi-Fi which is picking up DHCP from a Centos server.
    And to get it to do this look at network resources inside the DMZ I had to go to the configuration and give that particular SSID lan access which it did not have as default.
    I think this is one of the defaults on this box that I applaud - unlike at least two others being;
    The default that means that when your Internet connection goes down it does not automatically redirect
    The defaults that turns off the guest Wi-Fi after four hours as we use guest as a security device rather than something as though we were offering it to people coming to a hotel - not that we run a hotel you understand
  • Harska
    Your sentence #1:
    There was some problem or wrong config in the network
    since you didn't get DHCP addresses from the DHCP server.
    Your sentence #2:
    That is the way it works normally. So now you propably don't
    have the earlier misconfiguration in the network anymore.
    Your ZyXEL is doing normal routing of IP traffic, hence your phone gets
    DHCP addresses over the wireless connection.
    Your ZyXEL is not distributing (or dealing with) the DHCP addresses;
    just doing normal routing of the traffic, between client and DHCP server.
    I tried to help, but it's very difficult to solve other people's mess up
    just by looking at the question; where many ot the key informations are missing.
    From now on; I quit talking rubbish. You solve yourself your problems.
