Help! Need old firmware V3.30(AACV.4) for Zyxel USG 100-PLUS
Alex_Khru
Alex_Khru Posts: 2
edited March 2023 in Security
Hello!
After trying update my Zyxel USG 100-PLUS to firmware 330AACV7ITS-WK48-r74988.bin Its no booting. I can't find old version firmware, may be someone have this?
BootModule Version: V1.17 | 12/01/2011 05:20:17
DRAM: Size = 256 Mbytes
Kernel Version: V2.6.25.4 | 2014-01-21 10:47:34
ZLD Version: V3.30(AACV.4) | 2014-01-22 09:25:01
Press any key to enter debug mode within 1 seconds.
BM cmd line: console=ttyS0,115200 root=/dev/ram init=zyinit "-r /dev/sda", address: 0x100000
Uncompressing Linux...done.
Start to check file system...
/dev/sda2: 26/17352 files (0.0% non-contiguous), 43785/69296 blocks
/dev/sda3: 122/41120 files (13.9% non-contiguous), 14335/163841 blocks
Done
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
missing codepage or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Kernel panic - not syncing: Attempted to kill init!
  • Zyxel_Emily
    Hi @Alex_Khru,
    You can download firmware 3.30(AACV.4) at this link. Follow the firmware recovery step in the release note to upload firmware to USG 100-PLUS via FTP. If the device is still not able to boot up, maybe it is hardware issue. You can consider the new model USG FLEX 200 or ATP200.
  • Zyxel_Emily
    Hi @Alex_Khru,
  • Thank you! It turned out to restore via FTP.
    Please tell me what is the latest firmware version for USG 100-PLUS? I was able to find 330AACV8ITS-WK41
  • Zyxel_Emily
    Hi @Alex_Khru,
    The latest firmware version of USG100-PLUS is 330AACV7ITS-WK48-r74988 which was released on 2016-12-02.
    330AACV8ITS-WK41-r74145 was released on 2016-10-14 and it is not the final version. Hence, we suggest you use 330AACV7ITS-WK48-r74988.
