VPN - Authentification with ADD
Omnisoftory
in Security
Do firewalls support Microsoft 365 AD authentication when connecting to a VPN?
Instead of creating all users in the firewall.
Best regards
Damien Vonlanthen
Hi @Omnisoftory ,
Greeting Forum, Azure AD used SAML for user authentication.
Since Zywall doesn't support SAML Auth so it can not be implemented on Zywall.
Thanks your understand.
Kevin
The most easy way is using a middleware Idp cloud to integrate.
Hi @Omnisoftory ,
Kevin
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
