Texts / translations in the device GUI
StefanZ
I noticed a lot of odd English within the GUI of my FLEX200.
Stuff like this:
Try new feature for free! With the new Device Insight, IT could gain enhanced visibility and control of the networks.
Talking about "mixed signals"… Can I try this for free? For how long? Oh it's free anyway and what are the odds Zyxel will remove it in the future?
And I am pretty sure that "visibility" should be "oversight" in this context.
Many texts are lacking possessive pronouns – just as the "IT" in the above sentence.
Is there a system in place where one can bug-report those kinds of things? After all it should be easy to fix as long as your firmware is somehow based on i18 or a similar localisation mechanism.
- Be concise: Use short, clear and concise text for buttons, labels, and menus in the GUI. Avoid long sentences and technical jargon.
- Use simple language: Use language that is easy to understand for the target audience. Avoid using complex vocabulary and technical terms that may confuse the user.
- Be consistent: Use consistent language and terminology throughout the GUI. This helps users to understand the interface better and navigate it easily. Yacine tv live
- Use visual cues: Use visual cues such as icons, symbols, and images to help users understand the functionality of different buttons and menus.
- 217 Nebula Ideas
- 583 USG FLEX H Series
- 297 Service & License
- 476 News and Release
