Multiple IKEv2 gateways in parallel
What I want to do:
- Have multiple IKEv2 gateways running in parallel named #1 and #2.
- Have multiple users with the same credentials sign into #1 to access one subnet
- Have one admin sign into #2 and access another subnet
Since using a IKEv2 certificate gateway fixes the servers' Local-ID-Type
and Local-ID-Content
to the certificates' Subject, you are left with only the Peer-ID
to distinguish between requests to all gateways.
With only one gateway, I can set Peer-ID
to “any” and then enter a unique sting for each client to have multiple clients connect to the gateway at the same time, receive a unique IP in the correct subnet and all is good.
When I add a second gateway, the Zyxel device (FLEX200) fails to distinguish between gateways when both gateways are using the same FQDN/DDNS hostname. So I made the second gateway use another FQDN/DDNS – which of cause resolves to the same WAN IP, but still gives a unique Local-ID-Content
. At least so I thought…
Turns out, that the client still gets connected to the gateway with first precedence – deactivating that one will result in the second one working correctly.
Setting an email als Peer-ID
on both gateways solves that, but also disconnects any user on a gateway, as soon as a second user connects to it, because the gateway has no way of distinguishing between users anymore.
The Peer-ID
setting in the device only allows "any" or fixed values – no wildcards. Being able to enter *@myserver.com
for example would be swell.
My further ideas to get what I need:
- Use a second WAN-IP – in fact this device will at some point be deployed with 4 static IPs on WAN1 and 1 or 2 static IPs on WAN2, so that will "auto-solve" my problem. But that's quite a luxurious position to be in, many folks have to cope with only one IP. That's also what i have to work with for now.
- Make gateway #2 take precendence over #1 and only accept one specific Peer-ID. Other requests should be handed down to the next gateway – which then accepts "any" as Peer-ID and thereby allows for multiple users. Doing that in the GUI is not possible, the only way is to edit/sort the startup-config. Or create the gateways in the required order and then hope this ordern never gets messed up.
- Use only one gateway and handle the admin user differently from regular users. I was hoping for a different subnet/zone/vlan as landing point and therby avoid having to configure Security Policies for that…
I really wonder, why the different Hostname / Local-ID
doesn't work as expected. After all it has to match the cert?
Any ideas / input are welcome!
Hi @StefanZ ,
Greeting Forum, I tested the scenario. It works.
Please kindly refer the following settings:
1)Create two Phase1 VPN gateway. For local ID use the same certificate. For Peer ID use different DNS to identify.
(Phase1 profile: test1)
(Phase1 profile: test2)
2)Create two phase2 profile for them.
3) Change VPN client “local ID” to determine what profile would be connected
If local ID is “p1.com” , profile “test1_p2” is selected
If local ID is “p2.com” , profile “test2_p2” is selected
If there still have issue, please share your config files by private message. Thank you
Kevin
Yes sure, that works, BUT…
I cannot have multiple connections to neither of the two gateways, because all users would share the same Local-ID and user #2 would terminate user #1 when connecting.
What I don't understand: If my gateways have different FQDNs/DDNS and use that as their Local-ID, wouldn't that play into the selection of the gateway too? Or does the FLEX200 just see the request-IP at this stage (which would be the same for both FQDNs) and thus cannot differentiate?
Hi @StefanZ ,
All vpn profiles share the same Local-ID and VPN client set individual local ID (p1.com, p2.com) , When user2 connected user1 didn't terminate. It works at same time.
1)To reach the inqurirement, please set different Peer ID for individual profiles.
2)Peer ID / Local ID are just for identify, It doesn't matter if the value not the same as WAN address. The point is the valure must match with VPN client.
[profile1]
FW: Local ID: 1.1.1.1 , Peer ID: p1.com
Client: Local ID: p1.com , Peer ID: 1.1.1.1
[profile2]
FW: Local ID: 1.1.1.1 , Peer ID: p2.com
Client: Local ID: p2.com , Peer ID: 1.1.1.1
Thank you
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
