USG 20VPN web interface Blocked
Pedro_Brito
Pedro_Brito Posts: 5 image  Freshman Member
I put an additional port on the NAT and the connection to the router dropped, at the moment I can't access the router through the browser, I've already restarted the router and the problem remains, any tips to access the router and convert what was done in the NAT?
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    edited March 2023
    Hello @Pedro_Brito
    You can connect to the console port and access the device by SSH or Telnet, then use the CLI commands.
    Router#show logging entries keyword nat
    This command will show the logs related to NAT, maybe you can see the logs about the change of NAT settings. Please note that the log may be washed if there are much newer logs.
    Router# show ip virtual-server
    This command will show all the virtual server profiles, and find the profile name of the rule you edit.
    Router# configure terminal
    Router(config)# ip virtual-server deactivate <profile_name>
    This command will disable the specific virtual server profile
    Please refer to the CLI guide if you want to edit the virtual server profile settings by CLI.
    https://download.zyxel.com/USG20-VPN/cli_reference_guide/USG20-VPN_5.35.pdf
  • Pedro_Brito
    Thanks, i will try but something tells me I'm going to have to reset the router.....:(
  • mMontana
    mMontana Posts: 1,481 image  Guru Member
    @Pedro_Brito USG20-VPN have in the box the cable for console access. Consider this as opportunity to revert/disable your NAT setup. Won't be fast & easy, but might save you to reconfigure the whole device.
  • Pedro_Brito
    Does anyone know the command to disable NAT?
  • Zyxel_James
    @Pedro_Brito
    As I mentioned, the CLI command can show the NAT profile and disable it.
  • Pedro_Brito
    Problem solved, thanks Zyxel_James for the tips, saved me a few hours of router reconfiguration :)
