Multiples VLAN behind unique SSID - 802.1x
NicolasRosa
Hi everyone,
We are using NWA5123-AC-HD, VPN300 and Windows NPS as radius.
Is there any way to configure multiples VLANs behind one SSID ?
The idea is that the VLAN assignment will be ruled by NPS.
So all users connect to the same SSID, but then get access to their own VLAN, depending on their LDAP group.
Regards,
Regards,
Hi @NicolasRosa
There are two ways to achieve your requirement on NXC.
1. Dynamic VLAN by radius server attribute
2. Dynamic VLAN by External User Group
The attachment is the SOP that we made for NXC. You could use VPN300 to instead of NXC. The GUI should be the same.
Thanks.
Joslyn5
Hi @NicolasRosa
Thanks.
Joslyn5
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
