Turn off QOS on switch GS-108S v2
You can't but really it should not cause problems if needed look for another switch like GS1100-16
Thanks Peter, that's a shame. Can't help but wonder if there's a
Unmanaged devices work “as shown” and cannot be configured.
If you want to “configure”/"edit"/"modify"/"do what i want" things you should buy managed/configurable devices. But… beware of what you buy and how you configure it 😉
Hi @Switchy
The GS-108S v2 switch is an unmanaged switch and does not have the capability to turn off QoS.
If you require the ability to turn off QoS, you will need to consider using a managed switch such as the Zyxel GS1200 series. Managed switches provide more advanced features, including the ability to configure QoS settings.
Please let me know if you have any further questions or concerns.
Nami
Nami
- 441 Beta Program
- 293 Service & License
