Turn off QOS on switch GS-108S v2
Switchy
Switchy Posts: 2 image  Freshman Member
Zyxel Certified Network Engineer Level 1 - Security First Comment
Hello, how do I turn off QOS on the GS-108S v2 switch? It has designated priority ports labelled on the back but I want them to all equal.
    PeterUK Posts: 4,307 image  Guru Member
    You can't but really it should not cause problems if needed look for another switch like GS1100-16
  • Switchy
    Thanks Peter, that's a shame. Can't help but wonder if there's a
  • mMontana
    mMontana Posts: 1,444 image  Guru Member
    Unmanaged devices work “as shown” and cannot be configured.
    If you want to “configure”/"edit"/"modify"/"do what i want" things you should buy managed/configurable devices. But… beware of what you buy and how you configure it 😉
  • Zyxel_Nami
    Zyxel_Nami Posts: 659 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hi @Switchy
    The GS-108S v2 switch is an unmanaged switch and does not have the capability to turn off QoS.
    If you require the ability to turn off QoS, you will need to consider using a managed switch such as the Zyxel GS1200 series. Managed switches provide more advanced features, including the ability to configure QoS settings.
    Please let me know if you have any further questions or concerns.
    Nami
    Nami
