GS1200-8 VLAN Issue
Hello all. I recently purchased a GS122-8 Managed Switch and a TP-Link AP300 in search of a way to segregate my network with VLANs. So, I previously I had a Linksys WRT3200ACM wireless router working fine as it was, but I waned to keep my security cameras separate from the rest of my network. What I did was add the AP300 and a ZyXEL GS122 Managed Switch. I can get everything working, at least talk to each other, when I have the AP300 in Access Point mode and on 1 VLAN. Once I change it to Multi-SSID mode, I can't seem to get things to work. I have my Router as the DHCP server, put my AP300 and my switch on a static IP, and have all my Default Gateways pointed to my router. As for my router, I left everything the same, and just shut off the radio.
On the switch, I set up 1 VLAN with all ports untagged, and everything talks (with the AP300 in Access Point mode). When I create a second VLAN while the AP300 is in multi-SSID mode, I put the port going to the router as VLAN 1 and VLAN 2 and Untagged, I have the second port going to the AP300 as VLAN 1 and2 Tagged, and ports 3-7 untagged on VLAN 1 with Port 8 Untagged on VLAN 2.
Anyone have any idea if I have anything set incorrectly?
Thanks in advance,
Mike
Can you provide more detail information about your problem?
1. What is the model name of ZYXEL product? GS122-8?? GS1200-8??
2. What is the firmware version of your ZYXEL product?
3. Is possible to explain what kind of the problem you encountered?0 -
ftp://ftp2.zyxel.com/GS1200-8/firmware/GS1200-8_V1.00(ABME.4)C0.zip
GS1200-8 has new firmware version V1.00(ABME.4)C0, it has fixed some VLAN issue.
You can try the latest FW to verify your problem.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
