USG Flex 100 L2TP VPN not letting me access shared folders of the LAN
Hi everyone I'm new here,
I'm learning how to configure a VPN with USG Flex 100 with guides I found around.
So, I have a server in my LAN (10.0.0.0/24) and I want the VPN users (192.168.50.0/24) to be able to access the shared folders of it, as of now it seems like they can't even see it.
Tried pinging some PC in the LAN but no response.
This is a NAT rule for the FTP to work from outside with our public IP.
Does anyone have any idea? Don't know if I should have posted something more usefull, in case just ask and I'll provide it ASAP.
I looked for it in Windows Defender Firewall and found this:
Sorry but I'm a newbie and thanks a lot for helping me
Does your server allow the communication to 192.168.50.0/24?
Sorry but I don't know what you mean, the folder is shared to "Everyone" if it answer it
"Everyone" is only local access via File & Folder Security Access (Share access or file/folder Rights). Does the server have its own OS Firewall and is that Firewall configured to allow traffic from 192.168.50.0/24 (foreign subnet)? Note also that some systems consider legacy services unsafe and can block them by default.
Hello @Rgnvdjfgdfg
Welcome to the Zyxel community. Why L2TP clients(192.168.50.0/24) cannot access your internal server(10.0.0.0/24), here are some troubleshooting tips that you can refer to:
- Please check routing-related settings such as security policies, allowed local VPN policy, etc. To make sure L2TP clients(192.168.50.0/24) can access the internal server(10.0.0.0/24).
- When you cannot access the internal server, you can check Monitor > Log > View Log to see if there are any dropped messages by which whom.
- Please make sure your internal server can be accessed, it could be a safe access protection on the internal server and you could disable it.
- Capturing packets on the internal server(10.0.0.0/24) to make sure it can receive requests from L2TP clients(192.168.50.0/24).
If you have other questions in the future, we welcome your questions.
Thanks.
As you suggested i created a policy route
but I still can't either ping or access to the LAN.
In the log it says nothing about this, it was the first thing i checked.
The server can be accessed, first time i setup the VPN i could ping AND access the server without any problem.. After that i tried disconnecting and reconnecting and it all stopped working.
Tried capturing packets but first time doing it and seems like nothing is arriving at the LAN..
Hello @Rgnvdjfgdfg
Thanks for your update. Can you provide the remote Web-GUI link session to us for further checks by private message? We will send a private message later, please check your e-mail inbox. We would like to chek your routing-related settings. Thanks.
windows firewall
- 217 Nebula Ideas
- 574 USG FLEX H Series
- 297 Service & License
- 474 News and Release
