Zywall 110 - 2 WAN traffic port
Goodmorning everyone
I wanted to ask a question but I do not know if it is feasible.
We have a zywall 110 and we not have a very fast ADSL connection.
We have activated a second ADSL line that we would like to configure on the second WAN port of the firewall but not only as a backup or make sure that only a certain type of traffic (identified by the port such as HTTP / 80 to pass it through the second WAN).
Is it possible or can the second port be used only for fail over or load balancing?
Thanks anyway to everyone
Best Regards
Maurizio
Hi @maurixone,Use policy route to control the traffic.You can configure incoming/source address/destination address based on your application.
Here is an example.Send the ZyWALL's daily report using WAN2 only.
5
WAN trunk may fulfill your requirement. Refer to the thread https://businessforum.zyxel.com/discussion/comment/4548#Comment_4548
In the WAN trunk setting, you can also set the algorithm (Weighted Round Robin, Least Load First or Spillover) to implement your wan trunk0 -
Excuse me so much. I meant to use the second wan to route only one type of traffic / port (eg HTTP / 80 or SMTP / 465).thank you and sorry for my english
Best Regards
Maurizio0 -
5 -
Thanks for all
:-)0
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 516 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 461 News and Release
- 4.3K FAQ
- 97 Security Highlight
