Assign Slave Ports to link aggregation on USG 500 Flex in V5.35(ABUJ.0)
Hello dear Community,
We are facing an "issue" trying to set-up our USG500 Flex on Firnware V5.35(ABUJ.0) with link-aggregation.
The second chapter of this post (802.1ad) corresponds pretty much exactly to what we want to set-up.
Unfortunately when trying to set-up the Slave Ports my choices are very different from all the guides I find.
My "port" choices:
Also in the running-config the ports are all assigned.
interface-name ge1 sfp
interface-name ge2 wan1
interface-name ge3 wan2
interface-name ge4 lan1
interface-name ge5 lan2
interface-name ge6 dmz
interface-name ge7 opt
interface-name ge8 reserved
My question is how can I set up the ports to be selectable as slaves for the LAG as in the following given example:
Thank you in advance for your time.
Here what I did to add port 6 & port 7 to an internal LAG interface,
- Select not used interface as member interface for LAG. And setup its IP address to 0.0.0.0/0.0.0.0
Also, I rename the interface to ge6 & ge7 for easy to remember the mapped port #.
2. Bind only one port to each member interface
3. Create LAG interface and add the member interfaces.
4. Create VLAN interface on top of the LAG interface.
Hello Lan31, I very much appreciate your effort to help me here.
I tried today the complete setup as described unfortunately i can't reach the desired result.
Here are the details i can provide from my side:
I set up the four ports of my lag as follows. Note before that i tried to have them in diefferent „Zones“ like DMZ. The result was the same:
The LAG is configured in the following way on the firewall side:
The switch is also set to handle LACP on the LAG:
Finally on the LAG i also setup a VLAN:
Now the issue i have in that form of setup, is that i can only ping the VLAN interface when GE7 which is on the original lan1 assignement is plugged in. Over none of the other links (GE4/5/6) I am able to ping the VLAN interface. The lag is clearly up though and i can’t be a negotiation thing as it doesn‘t work even with only one wire except for GE7.
Any idea where i went wrong?
For everybodies information. With the screenshots provided before and after a full reboot and reset of the configuration I am glad to say that it is now functionnal. Thank you for the help @lan31
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
