Monitor internet usage per IP
kaissi
kaissi Posts: 5 image  Freshman Member
Is there a way to monitor internet traffic per IP ? I have the USG110
I tried to check the monitor tab, it shows the traffic usage from the WAN side not LAN side (or per IP on the network).
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @kaissi ,
    Please kindly find the follwoing screenshot statistics and choose the interface as LAN.
    You will see the trafic statistics of internet traffic
    Thank you
  • kaissi
    got it thanks
