Secureporter popular websites not relevant
Hi @iSpeed,
Go to CONFIGURATION > Cloud CNM > SecuReporter.
Enable “Enable SecuReporter” and “Include Traffic Log”.
Go to MONITOR > UTM Statistics. Make sure “Collect Statistics” of each UTM service is enabled.
If all checkbox mentioned above are already enabled, we need more information to check this issue.
The required information will be sent in the private message.
Thank you. The collect statistics checkboxes were not checked. I did not see anywhere in the setup where those needed to be checked. I'll report back now that I have those checked.0
Ok, I've checked the collect statistics, but still no accurate data in popular websites, etc.0
Hi @iSpeed,The required information is already sent in the private message.You can check your inbox and follow the instructions in the message.0
Hi @iSpeed,
The root cause is that the traffic hits the security policy rule 1 (HTTP/HTTPS) and no CF profile is applied to this rule.
After CF profile is applied to rule 1, there are logs for popular website on the SecuReporter server now.
You can delete/disable rule 1 and then traffic will then hit rule 2.
Since data is sent to the server, you can monitor the CF reports on SecuReporter.
Please feel free to let us know if you have further questions on SecuReporter.
Emily, I was having a hard time getting it working on any other firewall. After a couple hours of testing I found the below. The EZ mode doesn't check the "log all web pages" in the CF UTM profile.
Hi @iSpeed,About the design that the EZ mode doesn't check the "log all web pages" in the CF UTM profile, we will check if it would be better to add an option to enable "log all web pages" in the security service ziward.Thanks for your suggestion.0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
