Traffico internet da pc
Gaetano
Gaetano Posts: 20  Freshman Member
Buongiorno vorrei sapere se esiste un monitor per poter controllare il traffico internet da singolo pc da un usg20-vpn, grazie
  • Zyxel_James
    Zyxel_James Posts: 667  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    You can send traffic logs to an external Syslog server or USB for tracking the traffic log for a single PC.
  • Zyxel_James
    Do you mean to control the internet traffic from a specific host through USG20-VPN? Bandwidth limit or UTM feature?
  • Gaetano
    No, I mean where he's sailing and at what time
  • Zyxel_James
    Could you describe more for your scenario? I think you need Security Policy for the single PC.
    Go to CONFIGURATION > Security Policy > Policy Control, and create a new rule for the PC. You can allow/deny/reject the traffic by the criteria you want, and you also can apply the schedule.
    Please refer to the articles
    https://community.zyxel.com/en/discussion/462/how-can-i-block-https-www-facebook-com
    https://community.zyxel.com/en/discussion/14682/how-to-block-youtube-access-by-schedule
    https://support.zyxel.eu/hc/en-us/articles/4404961579282-Adding-a-firewall-rule-security-policy-on-your-ATP-USG-FLEX-USG-ZyWall-Gateway
  • Gaetano
    My scenario is to monitor a single pc where it surfs and what time it visits certain sites.
  • Zyxel_James
  • Gaetano
    This could be a great idea. I'll try. Thanks for support.
