DNS_PROBE_STARTED / DNS_PROBE_FINISHED_NXDOMAIN / ERR_CONNECTION_REFUSED
I have this strange problem with a USG40.
Seems like it's at times refuses to let DNS Requests pass through.
Computers in the LAN won't be able to visit sites, then all upp the sudden they can.
They may need to try like 5-10 times before the site show up.
DNS_PROBE_STARTED / DNS_PROBE_FINISHED_NXDOMAIN / ERR_CONNECTION_REFUSED are all errors that have been displayed while they can't access the websites.
Does anyone have any ideas what this could be?
The windows server on the LAN serves as a DNS server and has forwarders set up for the ISP's DNS servers, have also tried to use 8.8.8.8 and the USG40 as forward adresses, but the problem persists.
What if you set a PC device with DNS for 8.8.8.8?
Hi @MicaelO,
Use the command to check if the DNS server provided by ISP works.
Router> nslookup <hostname/IP> server <DNS server's IP>
Example:
Router> nslookup www.zyxel.com server 168.95.195.100
You can also add an extra DNS server manually.
The three errors may come from DNS cache/Chrome or other software on Windows.
Here are some methods for your reference.
DNS_PROBE_STARTED
https://www.drivereasy.com/knowledge/fix-dns-probe-finished-nxdomain-chrome/
best fix is to change dns to 8.8.8.8 and 8.8.4.4, and flush dns
https://geeksadvice.com/how-to-fix-dns_probe_finished_nxdomain-error/
- 441 Beta Program
- 293 Service & License
