IPSec NATT (udp4500) ADP false udp filtered distributed portscan Action
jurusam
jurusam Posts: 6
edited March 2023 in Security
ATP500 fw v5.35
I have logs of ADP:
from WAN to Any, [type:Scan-Detection(49)] udp filtered distributed portscan Action:Drop Packet
Source: {vpn.client.IP}:4500
Destination: {wan.IP}:4500
That logs are with every VPN access connection (L2TP over IPSec with PSK - Windows native client)
I have already changed sensitivity of ADP scan detection to "low" ((portscan) UDP Portscan)
I have added allow list rule for IPSec NATT udp port (udp4500)
How to get exclude rule of ADP to natt udp port - I don't want to disable the "(portscan) UDP Portscan" rule. Or, why zyxel-atp identify vpn-connection as "distributed portscan"??
  • jurusam
    jurusam Posts: 6
    I wrote this in the wrong category - it should be in the Security category - someone could change it
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,442  Zyxel Employee
    Hi @jurusam,
    You can configure allow list rules to let certain IP addresses or services to bypass ADP flood detection.
  • jurusam
    jurusam Posts: 6
    I already wrote about it - I have enabled that feature - - it doesn' work
    …todays logs:
    PeterUK Posts: 4,034  Guru Member
    edited March 2023
    Test with any service
    does the problem happen when client does a speed test?
  • Zyxel_Emily
    Hi @jurusam,
    In the log, the traffic hits UDP portscan. Try to inactivate "(portscan) UDP Portscan" in ADP profile > Scan Detection and monitor if VPN connection is working. Then give me the remote access information of this ATP500 in private message. We will check if it is false positive.
  • jurusam
    jurusam Posts: 6
    VPN connection is stable (I think) - users didn't say that have problem.
    Today I have 4 vpn clients connected (Windows, Mac and Android) - working with RDP or http browsing of local web. With each of this connection there is log warning of "udp port scan" with action "access block".
    I tried with authentication of local ATP accounts or Win AD accounts - same thing
  • jurusam
    jurusam Posts: 6
    If this "access block" would cause problems with the connection - I would disable the rule. But now there is only warning in ATP device. I prefer to enable this rule to protect against other true port scans
  • vsdanie
    vsdanie Posts: 1
    The same thing happens to me with my flex500, I have to disable ADP for the ipsec vpn clients to work.
    In my case there are 4 clients that connect from the same office with their laptops using the zyxel IPSec VPN client.
    I have done the option described by jurusam and it does not solve.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @vsdanie ,
    Greeting Forum, We will have Allow List for ADP Port scan to avoid preventing known IPSec UDP packets.
    The feature is upcoming next FCS firmware April.
    Thank you
