view error counters on XGS1210-12
muetzekoeln
muetzekoeln Posts: 46 image  Freshman Member
First Answer First Comment Friend Collector Fourth Anniversary
edited July 2024 in Switch Ideas
For debugging purposes it would be very helpful if interface error counters would be accessible from web access.
4 votes
In Plan · Last Updated
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279 image  Guru Member
    Hi @muetzekoeln
    Thanks for your input! 😀 We'll be monitoring the votes and comments as part of our evaluation process.
    If anyone likes this idea, please show your support by leaving a comment or voting for it.
    Kay
    Kay
  • Zyxel_Kay
    Hi @muetzekoeln
    Could you please clarify if the CRC count is sufficient for your needs?
    Kay
    Kay
  • Zyxel_Kay
    Our valued users @danir and @gordonre have also proposed the addition of the CRC count display in the system tab interface for the XGS1250-12 switch, as seen in this thread:
    Due to the demand for this feature, we have decided to extend its implementation to the XGS1250-12 as well. This means that both the XGS1210-12 and XGS1250-12 switches will benefit from this enhancement.
    If any other community members have more ideas or feedback to share, please feel free to do so. We highly value your input.
    Kay
