Zyxel XMG3927-B50A Motherboard UART Pinout
I need to reload the standard factory issue firmare into a Zyxel XMG3927-B50A that has been locked down with many features including SSH disabled. I believe that I have identified the UART pins on the bottom of the motherboard in the photo above with a red rectangle. The right most pin appears to be ground but the other poins all show 3.3v with my basic multimeter.
Does anybody have the function of the other three pins between Rx, Tx and VCC?
Hello @Cycle
Welcome to the forum.
I was wondering if someone from Zyxel was going to answer this for you.
People in the OpenWRT community have done a lot with connecting to the UART pins on Zyxel devices, for example see https://openwrt.org/toh/zyxel/nbg6716
- from what I have read, buy a USB to 3v3 UART connection device and only connect to TxD, RxD and Ground.
I have not tried this myself. So you try this at your own risk. I don't work for ZyXEL.
Kind regards,
Tony
Normal standard they use:
G x ? ? ?
GND key RX TX 3V3 most likely1 -
Anyone tries this? What do you think?
- 244 Nebula Ideas
- 6.9K Security
- 803 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 329 Service & License
- 537 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
