From USG110 to USGFlex200, blocking management from WAN doesn't work anymore
Hi everyone,
I recenty changed an old Zywall USG 110 by a new USG Flex200. I couldn't import the same configuration because it's not the same model, so I had to set up the new one manually. It was not really a problem and it was quite quick because I have a simple configuration, but even with the same settings the behaviour is different about the remote management (from WAN).
I set up an SSL VPN, so I had to add "https" to the "default WAN to zywall" service. In order to block any access to the management interface from WAN, in the menu SYSTEM/WWW I add a rule to "Admin Service Control" like "zone:WAN Addresse:ALL Action:deny". It worked like a charm on the USG 110 since years (it shows "access deny" when trying to connect from WAN), but with the USG Flex200 I still have a full access to the management from WAN !
Some screenshoots :
- On the old USG110 :
2. On the new USG Flex200 :
But I still have access to the remote management from WAN with the USG Flex200. What I am doing wrong ?
Thanks !
Hi @rlacti ,
Welcome to Zyxel community.😀
You can check if device wan interface is in WAN zone member list.
Hi Zyxel_Cooldia,
Yes, my WAN port is "WAN1" and he is in the "WAN" zone :
I still don't understand why the behaviour is different between USG110 and USG Flex200 :-( .
Try doing it like this
But as to your problem maybe you had SSL in SSL_VPN zone and not set the SSL in WAN zone?
Hi @rlacti ,
Can you send me your startup configuraiton file in PM.
I would like to test based on your configuration file.
- 441 Beta Program
- 210 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
