IPSec Client GINA Position
Hi @CMPS,
You can move the GINA window to the top-right corner of Windows, and it will pop up on that position when you login.
https://www.dropbox.com/s/0dthf0j1mn71xvz/Video%202023-4-10%2C%205%2002%2053%20PM.mov?dl=00 -
Hello Emily,
thank you for your quick reply.
I know that you can move the window.
But many of our users have problems with moving it, especially on notebooks. Its a user problem....
I was hoping that you could adjust the default height.
As an example 40 pixels higher so the windows icons can be seen.0 -
Hi @CMPS,
About the request to "change the position of the GINA window in the Windows login of the ZyWALL IPSec VPN client", we already move this suggestion to idea section for future evaluation. Thanks for your suggestion.0 -
Hello Emily,
there is something else you can adjust.
There is a translation error in the German translation.
In the GINA window it calls "Geöffnet" for open and "Schließen" for close.
But it calls "Öffnen", not "Geöffnet".
"Geöffnet" means that it is already open.
The correct words are "Öffnen" and "Schließen".
Or "Verbinden" for connect and "Trennen" for disconnect.
Would be great if you could change this in the next client.Thanks
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
