Proxy ARP performance
Ok so I know that its
going to be slower then a switch network but the CPU is only hitting
30% when running a big file copy using MS file and printer sharing
getting about 244Mb transfer.
So I was thinking is the reason for this to do with the ZyWALL 110 Cavium CN6230 quad-core 1GHz CPU and how threads are handled so that traffic sending can only be handled by one core and not across all cores?
Are you sure its src IP/port and dst IP/port and not src IP and dst IP ? Tried running three sessions and the limit did not change.
thanks
Hi @PeterUK
Can you share with us how did you check the cpu core loading by GUI or? From the GUI or CLI, to realize the actual core usage, you can use:
Router# show cpu all
In addition, I'm also wondering that did you turned on all the UTM functions on the device (eg anti-virus, app patrol, content filter...etc) since the UTM functions may also affect the traffic.0 -
I have non of the UTM functions on (eg anti-virus, app patrol, content filter...etc)
I'm checking the bandwidth with task manager and copy and paste one big file at a time for their to be three sessions
This is the output of Router# show cpu all when running three sessions:
CPU core 0 utilization: 19 %
CPU core 0 utilization for 1 min: 15 %
CPU core 0 utilization for 5 min: 3 %
CPU core 1 utilization: 0 %
CPU core 1 utilization for 1 min: 0 %
CPU core 1 utilization for 5 min: 1 %
CPU core 2 utilization: 100 %
CPU core 2 utilization for 1 min: 92 %
CPU core 2 utilization for 5 min: 20 %
CPU core 3 utilization: 0 %
CPU core 3 utilization for 1 min: 0 %
CPU core 3 utilization for 5 min: 1 %
Hi @PeterUK
We just used the iPerf to check the throughput and as you can see the loading was separated to different cores. For your reference.//PC1 iperf clientd:\>iperf3.exe -c 192.168.101.33 -p 9997 -t 120d:\>iperf3.exe -c 192.168.101.33 -p 9998 -t 120//PC2 iperf serverc:\>iperf3.exe -s -p 9998 -i 5 -Vc:\>iperf3.exe -s -p 9997 -i 5 -V//USG consoleRouter> show cpu allCPU core 0 utilization: 25 %CPU core 0 utilization for 1 min: 26 %CPU core 0 utilization for 5 min: 12 %CPU core 1 utilization: 0 %CPU core 1 utilization for 1 min: 0 %CPU core 1 utilization for 5 min: 2 %CPU core 2 utilization: 20 %CPU core 2 utilization for 1 min: 24 %CPU core 2 utilization for 5 min: 21 %CPU core 3 utilization: 0 %CPU core 3 utilization for 1 min: 0 %CPU core 3 utilization for 5 min: 0 %0 -
Well its not doing it for TCP and MS file and printer sharing.
Ok found the answer with Tcpview it turns out to be a limitation with MS file and printer sharing you would think doing copy and paste one big file at a time for their to be three sessions would mean a new connection per src port to port 445 but no it does not.
When I copy and paste one big file at a time each it shares the same src IP/Port dst IP/Port.
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 467 USG FLEX H Series
- 307 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
