IPSec Client GINA Position
CMPS
CMPS Posts: 5  Freshman Member
Hi, is it possible to change the position of the GINA window in the Windows login of the ZyWALL IPSec VPN client? Unfortunately it covers the Windows 10 buttons for network and you have to move the GINA window.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,404  Zyxel Employee
    Hi @CMPS,
    You can move the GINA window to the top-right corner of Windows, and it will pop up on that position when you login.
    https://www.dropbox.com/s/0dthf0j1mn71xvz/Video%202023-4-10%2C%205%2002%2053%20PM.mov?dl=0
    See how you've made an impact in Zyxel Community this year!
    https://bit.ly/Your2024Moments_Community
  • CMPS
    Hello Emily,
    thank you for your quick reply.
    I know that you can move the window.
    But many of our users have problems with moving it, especially on notebooks. Its a user problem....
    I was hoping that you could adjust the default height.
    As an example 40 pixels higher so the windows icons can be seen.
  • Zyxel_Emily
    edited April 2023
    Hi @CMPS,
    About the request to "change the position of the GINA window in the Windows login of the ZyWALL IPSec VPN client", we already move this suggestion to idea section for future evaluation. Thanks for your suggestion.
  • CMPS
    Hello Emily,
    there is something else you can adjust.
    There is a translation error in the German translation.
    In the GINA window it calls "Geöffnet" for open and "Schließen" for close.
    But it calls "Öffnen", not "Geöffnet".
    "Geöffnet" means that it is already open.
    The correct words are "Öffnen" and "Schließen".
    Or "Verbinden" for connect and "Trennen" for disconnect.
    Would be great if you could change this in the next client.
