ATP 800 ADP white lists
alexey
alexey Posts: 193 image  Master Member
First Comment Friend Collector Eighth Anniversary
edited April 2023 in Security
We replace 2 usg1100 to 2 atp800.
Config were convert via converter.
After that each atp has many ADP alerts on any connections between sites (tcp/udp port scan), some aplications (as exchange DAG group, SIP, AD) stop work propely. Adding them to whitelist don't help.
How i can whitelist some addresses wo disable ADP between sites?
Other example:
src="client_ip:33462" dst="dns_ip:853" msg="Rule_id:2 from IPSec_VPN to Any, [type:TCP-Decoder(70)] obsolete-options Action:Drop Packet" note="ACCESS BLOCK" user="unknown" devID="aabbccddeeff" cat="ADP" class="" act="Drop Packet" sid=70 ob="0" ob_mac="000000000000"
ADP block DNS TLS request. How i can whitelist dns_tls to dns server?
FW V5.35(ABIQ.0)ITS-23WK12-0331-230301541 / 2023-03-31 09:04:28
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @alexey ,
    Greeting Forum, Please kindly set the Allow List for ADP service.
    If the issue peresist, Please kindly share the related logs and config file by private message.
    Thank you
  • alexey
    edited April 2023
    Hello @Zyxel_Kevin
    I wrote on 4th line of question that "Adding them to whitelist don't help"
    Config:
    service-object DNS_TLS tcp eq 853
    idp anomaly white-list activate
    idp anomaly white-list allow_dns_tls
    source local_range_ip destination dns service DNS_TLS
    activate
    Traffick blocks with messages
    src="ip_from_ local_range_ip:43108" dst=dns:853" msg="Rule_id:2 from IPSec_VPN to Any, [type:TCP-Decoder(70)] obsolete-options Action:Drop Packet" note="ACCESS BLOCK" user="unknown" devID="aabbccddeeff" cat="ADP" class="" act="Drop Packet" sid=70 ob="0" ob_mac="000000000000"
    Send config and logs to PM.
  • Zyxel_Kevin
    Hi @alexey ,
    The Allow list only for "Flooding Detection".
    We would recommend that applying other ADP Profiles for the rule.
    For example: you will have profile "customize_profile" and set Action "none" for TCP Decoder.
    Thank you
