how to block youtube USG FLEX 50W (USG20W-VPN) using content flitering
Techgate
Techgate Posts: 5 image  Freshman Member
I am trying to block youtube app using
using content flitering , youtube fall under streaming media and sharing I blocked them , even though I tried adding them in forbidden site list.
Still youtube app is working.
firmware version
V5.35(ABAR.0) / 2022-12-27 21:03:06
    PeterUK Posts: 4,267 image  Guru Member
    you may need to run
    debug content-filter https-domain-filter cache flush
    you may need to block from LAN to WAN UDP port 443
    you could block by FQDN address *googlevideo.com in the firewall
  • Techgate
    hi Peter,
    thanks for your response but what is the use of contect filter if need to block via FQDN address.
    i tried udp 443 didn't worked out.
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    edited April 2023
    You need to block YouTube by app patrol, but usg flex 50w doesn't have this feature. https://community.zyxel.com/en/discussion/14682/how-to-block-youtube-access-by-schedule
    edited April 2023
    If your sure UDP port 443 is blocked add the following to the list content filter:
    www.googlevideo.com
    googlevideo.com
    www.youtube.com
    youtube.com
    *.googlevideo*.com
    Then you must run command because USG stores allowed sites before you added them to Forbidden
