USG - Configuration Backup by Mail
ChrisGer
Hi ZYXEL Team,
USG's are able to send reports/alytes allreday, wouldn't it be an option to adapt the option to send also the startup.conf by mail to a mailbox? so you could set up an automated backup on existing modules (ok, must be a bit extended) ?
From ZYXEL's point of view, is this a solution for regular, automated backup of the current/running configuration on a USG?
Regards
Christian
Regards
Christian
This would be a good option.If you are a bit technical it is actually available in the FTP server of the router.You could make an automated program to extract it from there.
5 -
I do agree. The mail option should be easy to implement and would be a nice feature.The reason i said the FTP option, is that it is something that works right now. New features can be some time away0
Great idea!0
i have a nice feature if the cfg is sent by mail :)
It's called "Encryption password" :)
The admin is forced to set an "Encryption Password", so that the config is made "unreadable" before the verse with this password.
Of course you should know the "Encryption password" during restore. ?
In ZLD 4.60, it support to schedule backup the "startup-config.conf" with encryption password via mail.
will upgrade today and check the auto config backup via mail"
if the upgrade and function is successful, i leave a post in this thread.
update to 4.60 run well and no side effect messages trough console where shownthank for implementing the feature0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
