[Release Note] Small Business Access Point - NWA90AX V6.27 P4 firmware has been released
Small Business Access Point Firmware Release Note
V6.27 Patch 2
Date: January 10, 2022
Supported Platforms
NWA90AX V6.27(ACCV.2)
New Feature and Enhancements
Support new AP model. The NWA90AX is added to Nebula in this release. NWA90AX is a
Small Business Class NebulaFlex AP that supports standalone and Nebula cloud
managed mode.
Bug fix
N/A
Known Issue
Empty column stands for the mode is unaffected.
Mode |
CLD |
MGNT |
STD |
1. [eITS: 210400642] [Symptom] Mesh SSID is visible | V |
2. [eITS: 210900596] [Symptom] Act-session ID in access stage is different to accounting stage | V | V | V |
Patch 3 (Released on 2022-4-11)
New Features and Enhancements
N/A
Bug Fixed
Fix vulnerabilities CVE-2022-26531 and CVE-2022-26532.
Patch 4 (Released on 2022-6-22)
N/A
Bug Fixed
Mode |
CLD |
MGNT |
STD |
1. [eITS: 220600088] [Symptom] Client cannot get IP address after enable smart mesh | V | V | |
2. [eITS: 220600090] [Symptom] Client cannot connect due to driver abnormal L2 update frame transmission | V |
| V |
3. [eITS: 220400271] [Symptom] 5GHz channel width may be frozen in 20MHz even configure as 80MHz | V | V | |
4. [eITS: 220400958] [Symptom] NWA55AXE internet traffic not passed after reboot | V | V | |
5. [eITS: 211000989] [Symptom] NWA50AX not broadcast SSID due to openssl key issue | V |
| V |
6. [eITS: 211201294] [Symptom] NWA50AX / port usage display issue | V |
| V |
7. [eITS: 220400185] [Symptom] Station Fail connect to SSID with WPA2-Personal security method | V | V | |
8. [eITS: 220400302] [Symptom] Wi-Fi didn’t turn off after shutdown NWA50AX |
| V | |
9. [eITS: 210901238] [Symptom] NWA50AX bootup failure | V | V | |
10. [eITS: 211101095] [Symptom] NWA55AXE wireless bridge failure | V | ||
11. [eITS: 211200588] [Symptom] Schedule SSID does not working properly | V | V | |
12. [eITS: 220200836] [Symptom] Low downlink data rate on 11ax radio mode | V |
| V |
13. [eITS: 220600630] [Symptom] iOS device cannot connect SSID successful and display incorrect password | V |
Known Issue
Mode |
CLD |
MGNT |
STD |
how can I download latest firmware for NWA90AX ????
- 588 USG FLEX H Series
- 477 News and Release
