how to block youtube USG FLEX 50W (USG20W-VPN) using content flitering
I am trying to block youtube app using
using content flitering , youtube fall under streaming media and sharing I blocked them , even though I tried adding them in forbidden site list.
Still youtube app is working.
firmware version
V5.35(ABAR.0) / 2022-12-27 21:03:06
you may need to run
debug content-filter https-domain-filter cache flush
you may need to block from LAN to WAN UDP port 443
you could block by FQDN address *googlevideo.com in the firewall
hi Peter,
thanks for your response but what is the use of contect filter if need to block via FQDN address.
i tried udp 443 didn't worked out.
You need to block YouTube by app patrol, but usg flex 50w doesn't have this feature. https://community.zyxel.com/en/discussion/14682/how-to-block-youtube-access-by-schedule
If your sure UDP port 443 is blocked add the following to the list content filter:
googlevideo.com
youtube.com
Then you must run command because USG stores allowed sites before you added them to Forbidden
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
