Zyxel GS1350-18HP
Remon
Remon Posts: 6 image  Freshman Member
Hello, im new in VLANning on Zyxel Switch(es)
I have a GS1350-18HP and i want to activate VLAN1 (private) and VLAN2 (guest) on 5 ports
5 Accesspoints with 2 different SSIDs (Private and Guest)
VLAN configuration
add static VLAN
VLAN Group ID: 2
Port 2, 4, 6, 8, 10
Do i have to change this Normal, Fixed and do i have to activated Tx Tagging?
I hope someone can help me?
Kind regards,
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,587 image  Zyxel Employee
    Hi @Remon,
    For the ports you listed, please change them to "fixed". This configuration is to make these ports become VLAN 2 members. Also, each port should activate Tx Tagging. This makes the switch forward the packets with the VLAN tag.
    In addition, you could also reference our handbook chapter 2.1 to set up the VLAN configuration.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Remon,
    Zyxel Melen
