vision stencils
Maarten
Maarten Posts: 7 image  Freshman Member
is it possible to find the visio stencils for the gs2220-10hp, gs2220-28hp and gs2220-50hp somewhere?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,668 image  Zyxel Employee
    Hi @Ilia,
    GS2200 series doesn't have a GS2200-10 model. Do you mean GS2220-10? If so, you can find it in the download library.
    You may also find the product icon of GS1900. The GS1200 doesn't have a product icon.
    Zyxel Melen
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 410 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Dear @Maarten
    Greetings.
    Now, we don't provide the visio stencil for GS2220-10hp, GS2220-28hp, and GS2220-50hp on our official website.
    Would you mind sharing where you are going to use it?
    Thanks.
    Ivan
  • Zyxel_Melen
    edited April 2023
    Hi @Maarten,
    I have sent the file to you by private message, please check your message box.
    Zyxel Melen
  • Ilia
    Ilia Posts: 2 image  Freshman Member
    Hello, team!
    We also needs at GS2200-10 visio stencils to compile pretty documentation for our network
    And GS1900, GS1200-8HP v2 too, if possibe
    Thanks!
  • Zyxel_Melen
    Hi @Ilia,
    Zyxel Melen
