crypto boost-tcp: how to use it
mMontana
mMontana Posts: 1,468 image  Guru Member
With ZLD 5.10 some "boost" of IPsec VPN was delivered to device which had it. So no USG40, USG40W, USG60, USG60W currently, but for USG20-VPN and USG20W-VPN.
How to sensefully use it?
  • Is it useful enable it on only one endpoint if the other one is not capable? Example: USG40 on client side, USG20-VPN on the server side, enable it only on server side could be useful?
  • Is it useful enable it the device is an L2TP server for roadwarriors connections?
Thanks for your time.
  • CHS
    CHS Posts: 181 image  Master Member
    It looks only supprot in 5.10 firmware. The other models without 5.10 version.
    In Site-to-Site scenario, of cause it has to apply in both of devices.
    This command should works in all of VPN tunnel.(Not only site to site VPN)
  • mMontana
    Thanks @CHS, i had the same impression. But I'd love a statement from Zyxel representatives.
  • mjr
    mjr Posts: 40 image  Freshman Member
    First Comment Friend Collector Eighth Anniversary
    any updates for the activation of "crypto boost-tcp" in future releases?
  • DimSum
    DimSum Posts: 1 image  Freshman Member
    edited April 2023
    • Is it useful enable it the device is an L2TP server for roadwarriors Sonic exe connections?
    But how to turn it on?
  • mjr
    How to enable/disable the enhancement:
    To enable the enhancement by CLI command, use:
    Router(config)# crypto boost-tcp
    To disable the enhancement by CLI command use:
    Router(config)#no crypto boost-tcp
