crypto boost-tcp: how to use it
With ZLD 5.10 some "boost" of IPsec VPN was delivered to device which had it. So no USG40, USG40W, USG60, USG60W currently, but for USG20-VPN and USG20W-VPN.
How to sensefully use it?
- Is it useful enable it on only one endpoint if the other one is not capable? Example: USG40 on client side, USG20-VPN on the server side, enable it only on server side could be useful?
- Is it useful enable it the device is an L2TP server for roadwarriors connections?
Thanks for your time.
It looks only supprot in 5.10 firmware. The other models without 5.10 version.
In Site-to-Site scenario, of cause it has to apply in both of devices.
This command should works in all of VPN tunnel.(Not only site to site VPN)0 -
any updates for the activation of "crypto boost-tcp" in future releases?
How to sensefully use it?Is it useful enable it on only one endpoint if the other one is not capable? Example: USG40 on client side, USG20-VPN on the server side, enable it only on server side could be useful?Is it useful enable it the device is an L2TP server for roadwarriorsSonic execonnections?
Thanks for your time.But how to turn it on?
How to enable/disable the enhancement:
To enable the enhancement by CLI command, use:
Router(config)# crypto boost-tcp
To disable the enhancement by CLI command use:
Router(config)#no crypto boost-tcp
- 588 USG FLEX H Series
- 477 News and Release
