AP-Firmware by NXC2500 / USG210
FrankLauer
FrankLauer Posts: 51 image  Ally Member
First Comment First Answer Friend Collector Fifth Anniversary
edited May 2024 in Wireless
I manage different WAC6103D-I access points either with a NXC2500 or with a USG210.
I see that the firmware for the WAC6103D-I is on the USG210 the latest version: V6.28(AAXH.0) than on the NXC2500: V6.25(AAXH.8)
So, when I connect an access point from one to another controller first it up- or downgrades always the firmware.
How can I have the newest AP firmware on the NXC2500?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    edited April 2023 Answer ✓
    Hi @FrankLauer ,
    I would like to provide updated information. The most recent firmware version available for the WAC6103D-I on the NXC2500's AP firmware list is V6.25(AAXH.8). As per our plan, we may not be upgrading the NXC2500's AP firmware list any further.
    If you wish to use V6.28(AAXH.0) for a WAC6103D-I managed by the NXC2500, you can do so by following these steps:
    1. Go to NXC2500 > Configuration > Wireless > AP Management > AP Policy > Firmware Updating > Updating Mode, and choose Manual,click Apply
    2. Download the WAC6103D-I's V6.28(AAXH.0) firmware here and upgrade the firmware by FTP.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    edited April 2023
    Hi @FrankLauer ,
    Please go to NXC2500 > Configuration > Wireless > AP Management > Firmware > Click Check and Apply to get the latest FW version for your WAC6103D-I.
    Zyxel_Judy
    Untitled Image
  • FrankLauer
    Thank you for response. However the check I made already before. At the moment I have these results:
    USG210:
    V6.40 Patch 6 Success, 2023-04-18 17:51:06
    FW for WAC6103D-I Local / V6.28(AAXH.0)
    NXC2500:
    V6.30 Patch 4-6.45 Patch 0 / Success, 2023-04-18 17:51:47
    FW for WAC6103D-I Local / V6.25(AAXH.8)
    Pressing the button "Apply" results in this message: "Runtime firmware and available firmware are the same version."
  • Zyxel_Judy
    Hi @FrankLauer ,
    Zyxel_Judy
    Untitled Image
  • FrankLauer
    Thanks, that worked for me.
    And with a FTP client like FileZilla it also easy to upgrade a lot of APs in short time by FTP.
