Zyxel XGS1210-12 LAG
cozycat22
cozycat22 Posts: 1 image  Freshman Member
Someone had previously inquired about a bug where the switch loses LAG configuration either after reboot or otherwise randomly. Is there any kind of fix for this? In my case, the LAG configuration disappeared after a reboot. The LAG also seems to disappear if all ports in the LAG enter a down state (i.e. the upstream switch is shut down). The original post said a fix would be likely in 2023 2H - any suggestions before then? When the LAG interface goes down, it is quite disruptive.
I do have the latest firmware installed on the switch (V1.00(ABTY.6)C0).
Thanks.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,593 image  Zyxel Employee
    edited April 2023
    Hi @cozycat22,
    Welcome to the Zyxel community!
    Before the next official firmware is released, you could post your requirement on the Zyxel community.
    We will provide you the date code firmware to you via private message.
    I have sent it to you. Please check your message box.
    Zyxel Melen
