PC Not Working in Switch>Phone>PC Setup - GS1900-10HP
I have a GS1900-10HP switch that I am trying to configure for a setup like the following.
Switch>Phone>PC
Switch is on the Default VLAN 1
Phone is on VOIP VLAN 1040
PC is on Data VLAN 4
The phone works fine, however the PC continues to not work. I have double checked the DHCP server address on the switch along with the IPs and GW.
Current configuration looks like the following.
interface 5
switchport hybrid allowed vlan add 1040 tagged
switchport hybrid allowed vlan add 4 untagged
switchport hybrid allowed vlan remove 1
voice-vlan
! Boot Version: V2.0.2.1 | 05/21/2021
! Firmware Version: V2.70(AAZI.1) | 01/11/2022
Please advise
Hi @JYeags,
Welcome to the Zyxel community!
I have some advice for you:
- Please set up PVID 4 on Interface 5. The path is "Configuration > VLAN > VLAN > port".
The configuration will be "switchport hybrid pvid 4". - Don't forget the switch uplink/DHCP port should be set as tagged.
I hope it helps.
Zyxel Melen0 - Please set up PVID 4 on Interface 5. The path is "Configuration > VLAN > VLAN > port".
Hi @JYeags,
I hope it helps.
Setting the PVID on these ports made it work as expected. Thank you.
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
