snmp
after firmware v480 the SNMP is disable?
Hi @Sinbadtiburon37 ,
Hi @sinbadtiburon37,
We would like to gather more information to assist you to solve the issue, so could you share with us:
- The model name
- The firmware version before you upgraded the firmware to V4.80
- The management mode: standalone mode or cloud mode
- The detail symptom like your switch is on standalone mode’s GUI, at first your SNMP is enable, however after you upgraded your switch to V4.80, the SNMP is disable? Or your switch is managed by Nebula, on the Nebla GUI, the SNMP is enable, however the SNMP tool is not work, ect.
Zyxel_Judy
Hi, judy
Model: XS1930-10
Firmware before upgraded: 470
Presen firmware 480
It is standalone mode
In the dashboard under Quik Link it show (SNMP STATUS) !s in red
You mention SNMP STATUS shows ! in red should look like the screen below. It is just a Security warning, not disable status.
The SNMP community is used for SNMP management and is set to public by default. To avoid security breach, please change the community string to a value other than default setting.
If SNMP is enabled in W4.70, it will remain enabled after upgrading to 4.80. However, in W4.80, resetting to its default configuration will disable SNMP as our spec. In case, you'd like to enable SNMP, please go to Security > Access control > Service Access Control. Don't forget to change the SNMP community as well.
Zyxel_Judy
hi do I have to change default community settings if im using snmp v3 which does not utilize communities?
- 441 Beta Program
- 293 Service & License
