snmp
Sinbadtiburon37
Sinbadtiburon37 Posts: 3 image  Freshman Member
after firmware v480 the SNMP is disable?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @Sinbadtiburon37 ,
    Hi @sinbadtiburon37,
    We would like to gather more information to assist you to solve the issue, so could you share with us:
    1. The model name
    2. The firmware version before you upgraded the firmware to V4.80
    3. The management mode: standalone mode or cloud mode
    4. The detail symptom like your switch is on standalone mode’s GUI, at first your SNMP is enable, however after you upgraded your switch to V4.80, the SNMP is disable? Or your switch is managed by Nebula, on the Nebla GUI, the SNMP is enable, however the SNMP tool is not work, ect.
    Zyxel_Judy
    Untitled Image
  • Sinbadtiburon37
    Hi, judy
    Model: XS1930-10
    Firmware before upgraded: 470
    Presen firmware 480
    It is standalone mode
    In the dashboard under Quik Link it show (SNMP STATUS) !s in red
  • Zyxel_Judy
    edited April 2023
    You mention SNMP STATUS shows ! in red should look like the screen below. It is just a Security warning, not disable status.
    The SNMP community is used for SNMP management and is set to public by default. To avoid security breach, please change the community string to a value other than default setting.
    If SNMP is enabled in W4.70, it will remain enabled after upgrading to 4.80. However, in W4.80, resetting to its default configuration will disable SNMP as our spec. In case, you'd like to enable SNMP, please go to Security > Access control > Service Access Control. Don't forget to change the SNMP community as well.
    Zyxel_Judy
    Untitled Image
  • MartinSkv
    MartinSkv Posts: 4 image  Freshman Member
    hi do I have to change default community settings if im using snmp v3 which does not utilize communities?
